how big of tires will fit
by jsyeager » Fri Sep 17, 2010 8:04 am
i have a 2007 trailblazer with a 3" lift and 1.5 spacers what is the max tire size that will fit thanks
jsyeager
by bartonmd » Fri Sep 17, 2010 8:07 am
The sticky at the top of the forum you posted this thread in:
"Maximum Trailblazer Tire Size without Modification"
viewtopic.php?f=14&t=763
by HARDTRAILZ » Fri Sep 17, 2010 8:56 am
You can prolly fit a 6 and 7/8 in there
by bartonmd » Fri Sep 17, 2010 9:04 am
What are you talking about?!?!
He can fit at LEAST a 7" tall tire with a lift! Maybe even 7-1/2"!
Mike :friday:
by Gordinho80 » Fri Sep 17, 2010 9:57 am
7 1/2" is pushing it... 7"-7 1/4" MAX!!!
by bartonmd » Fri Sep 17, 2010 9:59 am
Screw it! 7-1/2 and get the Sawzall out!
by fishsticks » Fri Sep 17, 2010 12:26 pm
I flipped my UCAs and was able to get a 9" tire under mine!
by bartonmd » Fri Sep 17, 2010 12:27 pm
WOW!
by fishsticks » Fri Sep 17, 2010 12:40 pm
You know, I feel a little lame now since I actually clicked on the link Mike posted and it only talks about tire size for unmodified trucks. :wallbash:
Personal experience: I have 4" of suspension lift, 32x10.5 tires, and 25mm offset wheels (like having 1" wheel spacers). My tires rubbed on the plastic liners when I still had them in front. They still rub on the rear liners. I don't have sway bars.
by get_over_it » Fri Sep 17, 2010 12:52 pm
fishsticks wrote:I flipped my UCAs and was able to get a 9" tire under mine!
Is that with or with out a Body lift?
I found some tires and rims for ya, you just need to find wheel adapters now!
get_over_it
by HARDTRAILZ » Sun Sep 19, 2010 2:15 am
"I give it a ten, a //// ten"
by jsyeager » Wed Sep 22, 2010 6:28 am
will 255/65/17 fit on my trailblazer without rubbing with 3" lift and 1.50 wheel spacers if so how big can i go before t hit
Reason: Similar Topics Merged
jsyeager
by Philberto » Wed Sep 22, 2010 6:33 am
Please search around the site before posting this question. I am confident you'll find the answers you seek.
by cbbryan » Wed Sep 22, 2010 9:41 am
You could always go to the place you plan to buy the tires and ask them to try on different sizes to see what is the biggest that will fit with out rubbing.
cbbryan
by Trail X » Sat Sep 25, 2010 11:09 am
We don't have a "ultimate tire size" thread because there are so many options and combinations for both tire size and lifts. With so many variables, a finite algorithm is nearly impossible. I recommend searching through the build threads to get an idea of what size you can use.
The other option is to measure the clearance you have currently to the closest part of the body of the vehicle, then mathematically figure out what you can fit... remember that width and diamater of the tire will play into this.
Good luck. And don't mind these guys, we don't like to spoon feed information that we feel is generally avaliable somewhere on this site.
