Tire size advice please
by Regulator1175 » Tue Aug 17, 2010 11:49 am
I am going to be hitting the order button later tonight on a new set of tires. I would like some advice on tire size to order.
I have 2.5" suspension / 3" body lifts and am not afraid to cut. I have the 3.73 gears so I am a bit concerned how the larger tires will fare with them.
I am going to be going with the Tread Wright Guard Dog M/T's but am back and forth on size.
285/70/17 D Rating:$649.45 (5 tires)
Tread Depth: 19/32”
Meas. Rim Width: 8.5"
Tread Width: 9.1”
Rim Width Range: 7.5-9”
Max Load: 3,195 lbs
Outer Diameter: 33.3”
Max PSI: 65 psi
Section Width: 11.5”
265/70/17 C rating: $518.50 (5 tires)
Tread Depth: 19/32”
Meas. Rim Width: 8”
Tread Width: 8.75”
Rim Width Range: 7-8.5”
Max Load: 2,470 lbs
Outer Diameter: 32.25”
Max PSI: 50 psi
Section Width: 10.7”
Is the extra 1" in tire height and .25" in width worth an extra $130 out of the wallet?
by MrSmithsTB » Tue Aug 17, 2010 1:18 pm
Get the 285s. The size difference is more noticeable than you think. Anything smaller will look silly with the body lift. And that 1/2" ground clearance actually can come in handy.
by HARDTRAILZ » Tue Aug 17, 2010 1:20 pm
285's.
.5 inch of ground clearance is worth it. You need to keep in mind that you lose clearance when airing down so i would try and stick with as much as possible.
if you did not drive so much I would tell you to buy the 34's from me, but I wouldnt want to have them on the highway as much as you are.
I am really really looking for some 35's so take a look in your area if you can...
by Regulator1175 » Tue Aug 17, 2010 1:24 pm
I have a set of slightly used 32's mounted on 8 lug steel rims I will sell you! :mrgreen:
Kyle - Check this link: http://fortwayne.craigslist.org/pts/1889310046.html
by The Roadie » Tue Aug 17, 2010 1:27 pm
32s are off the scale for small. Sell them to a CRV owner.
by HARDTRAILZ » Tue Aug 17, 2010 1:32 pm
I remember buying those 32's... :cheers: I think they were well worth the $10.50 I paid and the random stuff you got me to pay me back. They were a deal...now sell them and make us some money...or i can get them seperated to sell.
I like them. Need to see how much tread they have and make my swampers disappear. I think those would fit the bill nicely for my truck.
by Regulator1175 » Tue Aug 17, 2010 1:36 pm
Mail the guy and see if he will trade the swampers for them. He said he wanted the cash for new tires.
by Regulator1175 » Tue Aug 17, 2010 1:40 pm
The Roadie wrote:32s are off the scale for small. Sell them to a CRV owner.
I figure I best explain, don't want you to think I was serious.
The tires and wheels I was talking about was an ebay find of Kyle's. He paid $10 for them, but had me pick them up since they were in my area. The tires are junk, have enough tread to get you to discount tire to have a new set put on, and the rims needed some paint and alot of cleaning. I have tried a few times, unsuccessfully, to sell them. They are currently still sitting in my garage.
You want to buy them? :thumleft:
by Trail X » Tue Aug 17, 2010 1:59 pm
Huh? :cry:
by irishboy02 » Tue Aug 17, 2010 3:02 pm
Go with the 285s. You wont regret it
2003 GMC Sierra z71
7" FTS lift
irishboy02
by OregTrailBlazin » Tue Aug 17, 2010 3:15 pm
Huh? :cry:
:Iagree:
:? guess I better step up a bit :cry:
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by KE7WOX » Tue Aug 17, 2010 5:08 pm
Huh? :cry:
:cry:
by glfredrick » Tue Aug 17, 2010 5:40 pm
I ran 265s on stock suspension on my 03... :) Go big! But also expect to run around a lot in 3 instead of OD. I had to do that with the 265s, and I switched back to 255s for street use.
glfredrick
Contributing Author
