How far do your tires stick out, photos?
by Opeth » Sat Apr 28, 2012 8:43 pm
I've been trolling through build threads, offset threads trying to get an idea on what to order in wheels. I've been waiting for almost 2 months now for a set I ordered back in February, which have been pushed out until the end of June now. I can't wait any longer is the bottom line but I cannot find another set that look similar with the +25mm offset and 17x7. The wheels I like are around 0 offset and 4.5" back spacing. I know it will stick out x amount, but I'm a visual person and need to see how it looks.
Do any of you guys have side body line shots and the nitty gritty specs on the wheels your running? ( back spacing, offset, sizing, spacer sizing) A thread like this if everyone contributes may be a good sticky to clear up future back spacing/offset
Sample shot: (sorry its my old tuner car in an early phase)
by Trail X » Mon Apr 30, 2012 11:05 am
Stock - and with mods:
255/75/R17 - 1.5" spacers - Stock Rims (7" wide, 6" BS)
by fishsticks » Tue May 01, 2012 5:30 pm
35x12.5x17
1.3" spacers
17x8 wheels, 25mm offset.
by Opeth » Mon May 07, 2012 2:17 am
Good photos, now just need some guys with the lower offsets to chime in. By the look of Donny's I'm glad I went with the 17x8 25 mm offset. I should be able to skate under Johnny law's radar only being out that far. The jeep guys up here are by far worse.
by fishsticks » Mon May 07, 2012 2:40 am
A 0 offset wheel is going to be very close to what I look like right now if you don't run a spacer... or are you looking at 6x5.5" wheels?
Also keep in mind my tire section width is 12.5".
by Opeth » Mon May 07, 2012 3:11 am
6x5.5 yes. Ultra wheel crusher 17x8, 1.5 spacer. 265/70 tires.
http://www.ultrawheel.com/wheel_detail. ... d=1&id=691
by navigator » Mon May 07, 2012 8:28 am
the rims you ordered (with 1.5 spacers) should stick out roughly 3.5 inches more than what you run stock.
by Opeth » Mon Nov 19, 2012 5:35 pm
Just my contribution. 17x8 25mm offset, 1.5" spacers, 265/70r17
Amount of cutting required...
by HARDTRAILZ » Tue Nov 20, 2012 11:20 am
Wheels
17 x 9
Backspace=4.75
Offset = -6mm
Spacers
1.3 inch Adaptors
Tires
315-70-17
Treadwright Guard Dogs
by HARDTRAILZ » Tue Nov 20, 2012 11:30 am
Rim Specs
Part Number---9089-7938
Hub Centris-- YES
Size--17x9
Bolt Pattern-- 6x5.5
Offset--6mm
Backspacing-- 4.75”
Load-- 2200lbs
Weight-- 27lbs
Jobber-- $246.85
Center Cap-- 9342141
Tire Specs
Part Number--67305
Size-- LT305/65R17
Load Range-- E
Sidewall--BW
Max Load-- 3195 lbs
Overall Diameter-- 32.8 in
Overall Width-- 12.2 in
Tread Width-- 10.0
Tread Depth-- 21.0/32nds
Rim Size--8.0-11.0
Weight--58.0 Lbs
by Melaronius » Wed Nov 28, 2012 3:52 am
Melaronius
by Harry Moto » Wed Dec 26, 2012 11:40 pm
2008 TB, 1.75" Smaxx front, 1.25" wheel adapters, 255/75-17 Silent Armor
At Native New Yorker I parked next to a TB with the stock suspension/tires, same color as mine. Cell phone pix, sorry for the quality.
2008 TB, 1.75" Smaxx front, 1.25" wheel adapters, 255/75-17 Silent Armor, compass mirror, 7" indash DVD/GPS, power passenger seat, & Mikes steel skid plate.
Harry Moto
by plaen » Wed Jan 09, 2013 5:13 pm
35x12.5 with 1.5" adapters on +0 offset rims
plaen
by 2000sdime » Wed Jan 09, 2013 7:09 pm
plaen wrote:35x12.5 with 1.5" adapters on +0 offset rims
That looks amazing I love it
02 Trailblazer LTZ (Stock)
2000sdime
