by HARDTRAILZ » Sat May 01, 2010 12:31 am
If you can do the diesel and wiring, that really is the hard part for what you want. Tranny and TC should be ok if you dont beat on it with the diesel torque. the rear would be simple if you slap some leaf springs in. Way simpler than our setup and alleviates the control arm issues of our stock set-up with bigger than 33's clearing.
The dana 44 is fine for both ends. a 60 of course would be stronger and better. I am sitting on a 44 for the front from a scout. To keep it simple and keep the stock rearend, but you probably have the better plan of changing suspension if you want 35's or over. I have a full size 44 and 14 bolt that would be pretty simple to swap in with all leaf springs.
What are you wanting to do for a front suspension? If you are cool with leaf springs, your budget will be more reasonable.
For steering I am looking at a box from a fullsize chevy car...impala or something and a basic crossover setup, nothing complicated, just simple.
My truck works almost too well do do a 2 to 5 grand swap for a solid front axle. I kind of wish i was in your position that I HAD to do something big anyway.
For what it sounds like you are wanting...I would do it simple first...leaf springs front and back///FYI we have spring over, but not leafs like spring over typically refers to///...basic steering like an older staight axle chevy or a crossover setup...whatever motor you want, I would go diesel before i wasted my time with an ss...The wiring and abs is out of my realm, but as you said...hardwire and make it work, then you can try to wire the rest back in.
