My idea
to plan out a SAS that would not beet a monster truck. It sounds silly but a ton of lift and anything bigger that 35" tires are not really what I was looking at.Here is what I had in mind.....if possible.
Using a Dana 30 front axle (not sure if I would go leaf or coil)
Using a rear sump oil pan (clearance and lower lift)
Toyota steering gear
custom bits to make it all work.
I'm thinking 6-7" of lift over stock would be nice. That way driving is daily, towing, highway use would not be diminished.
Also from what I gathered off the interweb the Dana 30 is about the same size as the 44, outside of a bigger ring gear and pumpkin. The pumpkin/ center section is what lead me to think the 30 would give me the most room to work with while keeping the lift in a reasonable range. The ring gear is a tad smaller at 7 1/8 vs 7.2 for the stock TB front. I'm not planning on rock crawling up a waterfall or jumping it threw the deserts of the Mojave. Again this is all speculation and thoughts. The big obstacle is when I showed my wife a few pictures of a SAS Trailblazer she said that its ridiculous....and "who needs a truck that high"
I'm going to look and see if that had run the 30 in the Cherokee. I had searched a little on the Hp and torque rating and couldn't find a definitive answer. Just a bunch of this year has weak axle shafts, that year had better (____) I would guess that a 4.0L jeep engine would be close to the 4.2 power ratings. Then again we are talking 2 valves per cylinder and cast iron vs 4 valves per cylinder and aluminium.
