Why not a hydraulic winch?
by Philberto » Fri Dec 18, 2009 7:07 pm
Hey everybody,
I was over on ExPo, and wondered to myself, if we are truly concerned with reliability and are going to have permanently-mounted winches anyways, why not go with a hydraulic winch setup? The cost is comparable, and there's no need to fuss with large amounts of electrical current in a potentially watery situation. I was looking at the Mile Marker H9000 as an example.
by The Roadie » Fri Dec 18, 2009 7:40 pm
Good for rock racers, IIRC. Bad if your engine is flooded out or you're at a 45 degree angle and can't run the engine to run the pump, where 12V works just fine under water. Until the battery is drained, then you get a jump from a buddies battery that's above water. I did a 45 degree hill climb in Moab and the oil pressure went away halfway up. A risk I never quantified before. :hissyfit:
by Philberto » Fri Dec 18, 2009 8:26 pm
Of course, the oil pressure situation could possibly be rectified by modifying the oil pan and/or the oil pickup tube...
And if you really wanted to, you could convert to a dry-sump system for relatively minimal cost. Something to keep in mind for rock-crawlers like yourself.
OT, you sent me a PM, but then deleted it prior to me being able to read it.
by foosh » Fri Dec 18, 2009 8:43 pm
Hmm... i really like it, i just doubt that our powersteering pump would produce enough line pressure to power it for long, notice they used a fullsize chevy for the test.
foosh
by teebes » Sat Dec 19, 2009 5:27 pm
Nothing stopping you from going hydraulic, other than time, money, etc :) Seeing more 'real' setups will always help folks decide down the road.
To me, batteries are a lot easier to replace or have secondary units available incase they fail. Pumps, not so much.
As Foosh mentioned, what kind of flow is needed on the pump side?
teebes
by Philberto » Sat Dec 19, 2009 5:55 pm
teebes wrote:Nothing stopping you from going hydraulic, other than time, money, etc :) Seeing more 'real' setups will always help folks decide down the road.
3.5GPM @ 1500PSI
Now to find out what the specs on our power steering pump are. And apparently the EXT and v8 models have a different power steering pump than the standard wheelbase.
-edit: Hey Bill, don't you have the contact info for the compnine guy? Maybe he could help us out!
