I did the same thing. Unbolted it, put the bolt in the nut, pounded the nut out, drilled new holes, pounded the bolt back in, then burned it in, bolted it back in. The back bolt stays the same. Essentially I copied chevycrew.
You gotta work on your posting man, I can usually figure out what you're trying to say, but it's pretty damn hard sometimes.
build thread All things in moderation, including moderation.
