Big plans for the heavy chevy
by DirtyBacon04 » Fri Sep 13, 2013 1:39 pm
Well, as we're aware, the Bacon's front diff is in need of medical attention. Medical attention that I dont have the skills to do. So much like a sick cat, my plan is to get rid of the broken diff and replace with a new one. While I'm at it, I figure i'll upgrade the ratio to 4.10. Since I'm doing that, I'll have to upgrade the rear ratio as well. But why replace the gears when I can replace the whole axle with an open 8.6". This is where having contacts came in handy today. I went to the shop/recycler that our Sheriff's Office contracts to do the heavy work on our cars. He was able to find me a front diff in 4.10 w/ 70k miles and a rear axle 8.6" non g80 in 4.10 for a total of ~1k (shipped). Keep in mind these both are being shipped from Alabama and Missouri. Not only that, he said I can use one of his bays and mechanics to help me do the work. Both axles should be in in appx 3 days. I'll recoop some of the $ w/ a core refund
Dont know how far up that crack goes
Since I'm going to have the diffs already out, obviously i will be replacing all the seals. I'll most likely go with a LockRight for the rear (not definate) but I didnt want to do a LR for the front due to the extra wear. If only the truetrac was avaliable for our front.... i think that would be ideal for us daily drivin, non-hardcore guys 8-)
Also going to be replacing all four front control arms because this is what my front/upper looks like it
None of my arms have ever been replaced, so seems like good opprotunity. To do all of them.
Also, I've ordered parts over the past few months/year that i've just been too lazy to install. I've got new bilstein HD's since on my Farewell West Coast tour I had to take one of Bill's old used regular bilsteins due to bushing failure on BDS lift. I also bought Marks 3" for the front that will be going in also. Need to order UBJ for obvious reasons.
I've also had the HD tie rods for over a year in a box... Also have had Mevo sway bar links for quite a few months waiting install. I was going to sell Marks 3" / bilstein hd combo for some radflo's. But this most recent axle issue has refocused my heavy spending. I'll get more benefit from the drivetrain upgrade.
by JorDaneeKey » Fri Sep 13, 2013 2:56 pm
:drool3:
JorDaneeKey
by Gordinho80 » Fri Sep 13, 2013 3:00 pm
Lots of 4.10s in the works... NICE!
by RyansTBLS » Fri Sep 13, 2013 8:26 pm
:lurk:
RyansTBLS
by v7guy » Sat Sep 14, 2013 2:44 am
it's true, this makes me happy. lookin forward to more pics!
by TBYODA » Sat Sep 14, 2013 10:01 am
DirtyBacon04 wrote: If only the truetrac was available for our front.... i think that would be ideal for us daily drivin, non-hardcore guys 8-) .
I agree and you would get real four wheel drive when not one wheel lifted in the air.
by mikekey » Sat Sep 14, 2013 10:19 am
I've had secret fantasies about quadrasteer. Trutrac would be nice too.
by The Roadie » Sat Sep 14, 2013 12:19 pm
A co-worker got a used Quadrasteer Suburban a couple of years ago. His turning radius was identical to the Roadiemobile, which was shocking. But looking at the control system (drive by wire - electric motor on the rack) made it unsuitable for offroading. The rear wheels steer opposite the front at low speeds, but in the same direction at high speed, I think. Making lane changes by just crabbing sideways, he said. I didn't confirm this with a look at a manual.
by mikekey » Sat Sep 14, 2013 12:31 pm
The Roadie wrote:A co-worker got a used Quadrasteer Suburban a couple of years ago. His turning radius was identical to the Roadiemobile, which was shocking. But looking at the control system (drive by wire - electric motor on the rack) made it unsuitable for offroading. The rear wheels steer opposite the front at low speeds, but in the same direction at high speed, I think. Making lane changes by just crabbing sideways, he said. I didn't confirm this with a look at a manual.
Sounds about right. Quadrasteer was really about improved towing. Not really something I'll do with the TB. But it's like portal axles. One can day dream of crazy ideas. :flex dirty:
by TBYODA » Sat Sep 14, 2013 8:18 pm
mikekey wrote:I've had secret fantasies about quadrasteer. Trutrac would be nice too.
I would assume those who used the Powertrax Lock-Right Locker in time destroy there front Differential?
by Moots1288 » Sat Sep 14, 2013 9:38 pm
only 2 have done it and have had everything else fail besides the frot diff.. I'm looking into installing one in my front diff in time.
by v7guy » Sun Sep 15, 2013 5:17 am
I believe last time we had a good thread on it, the general consensus was that the lockright would probably be fine with 33s. Even the carnage that was done on 35s was the result of full throttle, bouncing up hills with the wheels sharply turned. When Matt gets around to it I'm sure we'll find out how durable it really is.
by TBYODA » Sun Sep 15, 2013 8:31 am
If I jump in and went to re-gear I might as well add one add one at that time. But got to read that thread and see what the con's could be.
by DirtyBacon04 » Sun Sep 15, 2013 1:48 pm
The suspense is killing me. Whats worse is I'll probably have to wait till weekend after next to do the work. I picked up an extra shift this week and I'm already working all weekend.
by fishsticks » Mon Sep 16, 2013 9:13 am
TBYODA wrote:If I jump in and went to re-gear I might as well add one add one at that time. But got to read that thread and see what the con's could be.
Having to carry more spare parts. I learned how to swap a CV shaft on a hilift in around 10 minutes. :mrgreen:
Also, upgrade to 3/4 ton tie rods and bring spares.
Most of the breaking happens because the front locker turns EVERYTHING you're currently doing into Easy Mode, so you go looking for trouble. At least I did.
The spider gears in the front diff are RIDICULOUSLY small and weak. The Lockrite gets rid of those and therefore is a strength upgrade. I'd prefer all the other points of failure I had to deal with over having to pull out that front diff again.
I would recommend people regear before doing the front locker though. The crack in Bacon's front diff looks like the result of pinion walk. I have this theory that a higher ratio gear would help combat that.
by Shdwdrgn » Tue Sep 17, 2013 2:23 pm
DirtyBacon04 wrote:The suspense is killing me. Whats worse is I'll probably have to wait till weekend after next to do the work. I picked up an extra shift this week and I'm already working all weekend.
Don't you hate that? I was going to swap my rear last Saturday, then thought against it with all the flooding that was occurring. Now I wish I'd just gone ahead and done it. I'm also still trying to track down a quote for getting my computer reprogrammed to the new gear ratio.
Shdwdrgn
Contributing Author
by Regulator1175 » Tue Sep 17, 2013 11:58 pm
PCM for Less
by Shdwdrgn » Wed Sep 18, 2013 12:55 am
I have a PCMforLess tune. I also have HPTuners. So can anyone tell me what numbers I should change to adjust for the new gear ratio?
Shdwdrgn
Contributing Author
by djthumper » Wed Sep 18, 2013 2:09 am
Why don't you go to the HPTuners forums and ask? I am sure someone there can point you in the right direction.
by Shdwdrgn » Wed Sep 18, 2013 9:18 am
I've gotten less-than-spectacular responses from their forum in the past... Guess it can't hurt to try again, but I won't hold my breath.
I don't suppose anyone here has 4.10 gears and HPT, and can tell me what numbers they have entered on the speedo page? I can't think of any other settings that might affect this.
Shdwdrgn
Contributing Author
