Snorkel
by cbbryan » Wed Oct 28, 2009 12:04 am
I know on James' site and on the OS there was some talk of a modified Xterra snorkel, but I was thinking why not use a Tahoe snorkel. Since the TB looks like a little Tahoe it would seem like less modding would be needed to make it fit properly and function on a TB. Apparently either my google skills are lacking or there is not an after market snorkel for the Tahoe.
I did however come up with a few alternatives to trying to mod one; if you're going to mod, go all out and start from scratch:
The frist is a link to one of our fellow members here(02TahoeMD)on expidition portal and it shows what he did to mod a snorkel for his Tahoe.
http://www.expeditionportal.com/forum/archive/index.php/t-18269.html.
The second is one I found comes from off-road.com and it shows how to make one from scratch for the most part.
http://www.off-road.com/trucks4x4/article/articleDetail.jsp?id=399802
Reason: Updated url's to be links
cbbryan
by teebes » Wed Oct 28, 2009 12:40 am
Check out the OS for a good start: http://forums.trailvoy.com/showthread.p ... 199&page=8
I don't believe a finalized product was ever 'released' though. I believe the snorkel <-> airbox still needed to be finalized/sealed, etc.
Should help get you started, though :fro:
teebes
by Philberto » Wed Oct 28, 2009 2:02 am
Come to think of it, he's still posting, maybe he could enlighten us on whatever happened to the snorkel project... Unless he's too busy with coilovers :poke:
by Trail X » Wed Oct 28, 2009 10:11 am
OregTrailBlazin used a Tacoma snorkel if I recall. The issue was finding/modding an airbox to work properly, as the stock airbox is anything but sealed.
by janesy86 » Wed Oct 28, 2009 11:39 am
JD I think it was a 4Runner.. gotta check.
Edit... Looks like we were both right! :friday:
The snorkel is off a 95-04Taco/ 96-024Runner. I did have to cut the snorkel and Re-weld it back together to get its profile to match a bit better. I wish I had some pics of the process, it was beautiful. You cannot tell where I had to cut it.
by OregTrailBlazin » Wed Oct 28, 2009 2:01 pm
I figured it wouldn't take too long before a thread poped up, expecially after the last discussion about this on the introductions page... :work:
Fitting the Snorkel to the truck is no problem, the main thing is a new airbox/washer fluid combo. The airbox James found (on the OS) seems to be the ticket. The main thing that has been holding me up, is I can't weld Aluminum at the moment, and I want to build a new Washer Fluid Res out of Alloy. I'm sure someone could spend some time down at the junk yard and find the right washer bottle that would work just fine, but I like doing things the hard way :viking:
I'm sure I'll have some time soon to play with this again, BUT first the Coilovers :angry whip:
Reason: scaled your image down a tad :)
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by Trail X » Wed Oct 28, 2009 2:17 pm
How about you just take the snorkel off and send it to me?! I guarantee I'd have it done in a month. :poke:
And why are you messing with the washer res? Its far enough out of the way isn't it? Sure its ugly, but who cares!
by OregTrailBlazin » Wed Oct 28, 2009 2:26 pm
JamesDowning wrote:How about you just take the snorkel off and send it to me?! I guarantee I'd have it done in a month. :poke:
I can't get the intake through the inner fender without moving the washer bottle. If I went above where the Res is now, it would go through the fender too high, where there's not enough room for the 3" to run front to back. It also would also go right through the support Rail/tube like guy holding that fender and supporting the Radiator support. If I was willing to pull my fender off, and weld a cross tube through that fender support it wouldn't be a problem. But I would much prefer to just build a new washer Bottle!!
Think anyone could tell if we switched Fenders too? :awesome: :finger:
Johnny Kurz
General Manager
541-474-2879
Our Vendor Section
OregTrailBlazin
by Gordinho80 » Wed Oct 28, 2009 3:27 pm
The snorkel discussion has finally made its way over... will this finally result in a working unit?
by The Roadie » Wed Oct 28, 2009 6:14 pm
OregTrailBlazin wrote:...BUT first the Coilovers...
In my best Smeagol voice - "Yessssss, the precioussss coiloversssssss."
by foosh » Wed Oct 28, 2009 9:32 pm
Hey... So basically every snorkel for us will be unique, we need to find a way for a bunch of us to do it fairly easily!
foosh
by Philberto » Wed Oct 28, 2009 10:42 pm
Easiest, most ghetto-tastic way is 3" ABS tubing + rubber clamps attached to body work with the filter on top. :D
I saw an old Subaru with that once... Functional, but ugly as sin.
by foosh » Thu Oct 29, 2009 2:12 pm
I'm sure we've all seen some beater trucks with that set up, but theres no real way to use that in rain or when not going slow thru water. the filter set up like that can get water into it, or get wet from rain, then theres nothing else to stop the water from getting to the engine.
foosh
by The Roadie » Thu Oct 29, 2009 2:59 pm
You can do a ghetto but functional snorkel with a proper upper tip, even if this one is on backwards.
by Philberto » Thu Oct 29, 2009 7:22 pm
Or you could always use a "U" fitting on the top of the ABS and use an inline air filter.
by Zero » Thu Oct 29, 2009 10:12 pm
its so nice to see the snorkle discussion here.
by irishboy02 » Fri Oct 30, 2009 12:08 am
Zero wrote:its so nice to see the snorkle discussion here.
Agreed, now imagine how it would look completed on our vehicle :happy whip:
2003 GMC Sierra z71
7" FTS lift
irishboy02
by teebes » Sun Nov 01, 2009 6:25 pm
An alternative for some of you to consider. The unit Expeditions West has on their JK extends further down the body, similar to where our stock air box resides. Might negate the current issue w/ the washer fluid reservoir:
teebes
by MrSmithsTB » Sun Nov 01, 2009 6:53 pm
I am curious.... Does the body lift relocate all of those tanks, reservoirs, etc or do they stay in place. I would imagine they stay in place, and that a snorkel could be installed with considerably less modification.
by Trail X » Sun Nov 01, 2009 7:19 pm
The fluid reservior is bolted to the body, not the frame.
