My stockpile, it begins!
by Dirtyd » Wed Apr 25, 2012 3:23 pm
I bought a 2008 Trailblazer LS a couple weeks ago with 65k and have been ordering parts ever since. I finally got the tires via Ups today, getting them mounted tonight at work. Lift goes on tomorrow. I could not have done it without you guys. super excited!
You Only Live Once
Dirtyd
by navigator » Wed Apr 25, 2012 3:25 pm
are you missing two rims?
by Dirtyd » Wed Apr 25, 2012 3:34 pm
No there still in the box i just took two out.
You Only Live Once
Dirtyd
by DirtyBacon04 » Wed Apr 25, 2012 4:13 pm
Im excited for you! Can't wait to see what she looks like!
by NC_IslandRunner » Wed Apr 25, 2012 10:43 pm
Nice pile!
by Trail X » Thu Apr 26, 2012 9:48 am
What are the large black o-rings? I can't seem to place them...
by Me007gold » Thu Apr 26, 2012 10:32 am
Nice pile of parts. The only thing I see missing is the front struts.
Me007gold
by navigator » Thu Apr 26, 2012 10:37 am
Me007gold wrote:Nice pile of parts. The only thing I see missing is the front struts.
agree, unless your struts are pretty new go ahead and replace them while you have the front end apart.
by SaltWaterDrinker » Thu Apr 26, 2012 1:06 pm
Dude epic. Cant wait to see the results, as well. Especially that radio - that'll look fresh.
SaltWaterDrinker
by DirtyBacon04 » Thu Apr 26, 2012 1:23 pm
JamesDowning wrote:What are the large black o-rings? I can't seem to place them...
for some reason I have a feeling that they go to the center caps... Only semi-logical place that i can think of where they go.
by djthumper » Thu Apr 26, 2012 1:59 pm
Nice pile
by hobbstisdaman » Thu Apr 26, 2012 2:12 pm
What is the tire size? 255/something?
hobbstisdaman
by Dirtyd » Thu Apr 26, 2012 3:10 pm
there hub centric rings, tire size is 265/75/16
You Only Live Once
Dirtyd
by Dirtyd » Sun Apr 29, 2012 11:37 pm
front done rear stock
You Only Live Once
Dirtyd
by Mudwheelin » Sun Apr 29, 2012 11:45 pm
Looking good so far.
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by v7guy » Mon Apr 30, 2012 1:56 am
Looks nice! Now get the back done!
by hobbstisdaman » Mon Apr 30, 2012 5:20 pm
Take a picture of getting those rear springs in. I'm curious to see how people do it with just the tb jack and some stands
hobbstisdaman
by navigator » Mon Apr 30, 2012 7:51 pm
I put in Z71 springs with a 3/4 spacer.
All I did was jack the rear up, put the frame on jackstands.
Remove the rear wheels.
disconnect the rear shocks
unhook the brake line anchor point so you get more play.
lower the rear end.
I then put the spacer on top of the spring and used a pry-bar to push everything in place.
I didn't disconnect the sway bar but I think that would have made it easier.
Reverse the order to put it all back together.
by Saxis » Mon Apr 30, 2012 7:59 pm
I did about the same as Chris, except I have the BDS lift. Just had to lock those into the AirRide mounting holes, then I lied down under the axle and just bench pressed the Z71s into place. It was tight, but I could compress them just enough to slide the bottom over the perch.
Saxis
by fishsticks » Tue May 01, 2012 5:20 pm
The swaybar is a big hangup. If I disconnect my rear shocks and let my axle hang the springs fall out. :mrgreen:
