Ground Clearance/ Frame Clearance/ Slider Clearance
by HARDTRAILZ » Tue Aug 17, 2010 2:04 pm
I plan to measure these tonight with the 34's and and with the Pro Comps.
I would love to see everyone elses numbers for this. Measure frame clearance in line with pillar between the doors and slider clearance there as well. Prolly measure slider clearance from lower bar and outside upper bar. Also measure ground clearance from front edge of oil skid. That should help give us similar numbers to see what is what.
by fishsticks » Tue Aug 17, 2010 4:45 pm
With 32" Hankook MT RT03s.
Frame to ground~ 13.5"
Lower inner rail of sliders~ N/A
Upper outer rail of sliders~ N/A
Front lip of oil skid~ 13.5"
ETA: Made mine look like the others.
by janesy86 » Tue Aug 17, 2010 4:55 pm
With 32" Kumho MT's...
Frame to ground~ 12"
Lower inner rail of sliders~ 13.5"
Upper outer rail of sliders~ 15.75"
Front lip of oil skid~ 11"
by HARDTRAILZ » Tue Aug 17, 2010 8:28 pm
With 34" Swamper LTB...
Frame to ground~ 14"
Lower inner rail of sliders~ 18.5"
Upper outer rail of sliders~ 21"
Front lip of oil skid~ 15"
by Trail X » Tue Aug 17, 2010 9:54 pm
With worn BFG 32"s...
Lower inner rail of sliders~ 14-1/8"
Upper outer rail of sliders~ 16-3/4"
Front lip of oil skid~ 11-1/8" (sagged 1" from when the lift first went on)
by rgraboske » Tue Aug 17, 2010 9:55 pm
From memory I know that my stocker is 9" from frame to ground. Do you want the other measurements for reference?
rgraboske
by Trail X » Tue Aug 17, 2010 9:58 pm
HARDTRAILZ wrote:With 34" Swamper LTB...
You have negative rake?
by fishsticks » Tue Aug 17, 2010 10:14 pm
I think he ended up with some after the 88 springs.
by HARDTRAILZ » Wed Aug 18, 2010 8:32 am
At the moment i do. I am trying to decide which way to go for the next 6 months or so. I can add another rear spacer or I can drop out the front shim. I need to replace balljoints or may just keep tires rotated if i am gonn rip out the whole suspension anyway and say the couple hundred from the joints for the sas. It was 14 to the tie bara across the frame, which is horseshoed BAD now, but it was probably closer to 14.5 to the actual framerail.
